2001 Dodge Stratus ac
2001 DODGE STRATUS
118,000 MILES • 4 CYL • 2WD • AUTOMATIC
ALENGAUER
My 2001 Dodge Stratus air conditioning is only working the first few minutes it runs and then just the fan blows. Someone told me it could be a coil in the compressor...is this so? Or is it more than likely an electrical problem/freon leak? I put a can of freon in it the other day and it still only worked for about half an hour.
May 26, 2009 at 7:20 PM
BMRFIXIT
  • 19,053 POSTS
1st step should be checking system pressure /and for leak
I would suspect low on 134A GAS
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
May 28, 2009 at 5:24 AM
