2005 Dodge Stratus Air Conditioning leaking water
2005 DODGE STRATUS
72,000 MILES • 6 CYL • FWD • AUTOMATIC
PAT78046
My air conditioning works fine the only problem I have is that the water from the air conditioning is dripping to the inside instead of to the outside. I have water coming in to the passengers side floor. Please advise.
Jul 5, 2010 at 9:32 PM
  • 110,194 POSTS
Hi:
It sounds like the drain tube is clogged. I believe if you check under the hood on the passanger side of the firewall, you will see a black tube that points down toward the road. Check the end of it for obstruction. They pick up dirt and that is usually where the problem is.
Let me know if this helps.
Jul 8, 2010 at 6:52 PM
