HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Stratus
Engine
Symptoms
Not Running
1997 Dodge Stratus wont start
CADYJETMAN
MEMBER
1997 DODGE STRATUS
V8
FWD
AUTOMATIC
10,000 MILES
My car has no spark
Sunday, June 22nd, 2008 AT 8:35 PM
BMRFIXIT
MECHANIC
Check fuses and relays
check and change crank sensor
check timing belt
good luck
Have an automotive repair question!
Sign up and ask your automotive question !
https://www.2carpros.com/affiliate/uid/bmrfixit_1_tlid_1
SPONSORED LINKS
Sunday, June 22nd, 2008 AT 9:14 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1997 Dodge Stratus Will Not Start
1997 Dodge Stratus Will Not Start, Radio Does Not Play, Anti-theft Device Does Not Flash. A New Battery Was Installed After The Problem...
Asked by
waynespohn
1 ANSWER
1997
DODGE STRATUS
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
Will Not Start
Car Wont Start It Will Turn Over But Wont Start. I Have Replaced Crank And Cam Sensor, Fuel Filter, Also Had Coil Tested, Its Fine, Im...
Asked by
Damienp8244
1 ANSWER
1997
DODGE STRATUS
1997 Dodge Stratus Won't Start
Electrical Problem 1997 Dodge Stratus 4 Cyl Front Wheel Drive Automatic 157k Miles You Guys Helped Me With My 76 Chevy Truck. Now I'm...
Asked by
hydrodude
1997
DODGE STRATUS
1997 Dodge Stratus Wont Start
I Have Changed The Fuel Pump The Ignition Coil The Crank Sensor And The Ignition Sensor The Batterie Is Dead But When Being Jumped Sounds...
Asked by
aimeegutierrez
1997
DODGE STRATUS
Car Will Not Start
Car Was Idling Then All Of A Sudden Shut Off And Would Not Start Back Up. Replaced Cam Shaft And Crank Sensor Still Did Not Work. Replaced...
Asked by
ccarpenter05
2 IMAGES
2004
DODGE STRATUS
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Symptoms
Crankshaft Sensor Replacement
Online car repair manuals
