1991 Dodge Stealth Won't Shift
INTRUDER
I have a 1991 Dodge Stealth rt automatic trans with 86,000 miles that will not up shift or down shift through the gears manually or otherwise.The car seems to be in high gear only (very slow takeoff up till 45mph then picks up speed fine) car can be manually down shifted to 2nd or low gear at speed with no change (not dropping to lower gears) any suggestions on what to check? Thanks!
Mar 26, 2006 at 4:27 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
The first thing you should check is the transmission fluid level and condition. Make sure the fluid level is within the proper fill range and the fluid condition is not burnt or dark brown in color. Here are a few tutorials for automatic transmissions for service and repair:
Next let's run the codes to see if any are stored:
https://www.2carpros.com/articles/retrieve-trouble-codes-for-chrysler-dodge-plymouth-odb1-1995-and-earlier-car-mini-van-and-light-trucks
It sounds like the first gear shift solenoid is stuck and not working. Please go over these guides and get back to us.
Aug 21, 2021 at 9:03 PM
Suggested Repair
Check the automatic transmission fluid level and condition, retrieve stored trouble codes, and inspect the first gear shift solenoid, which may be stuck.
Conversation Summary
A 1991 Dodge Stealth RT automatic with 86,000 miles will not upshift or downshift and appears stuck in high gear, with very slow takeoff until about 45 mph. Manual selection of 2nd or low also produces no gear change. The expert advised checking fluid level and condition, retrieving trouble codes, and investigating a possibly stuck first gear shift solenoid.
