11 IGN reference signal.
13 MAP sensor pneumatic circuit.
14 MAP sensor electrical circuit.
15 Vehicle speed/distance sensor.
17 Engine running too cool.
21 Oxygen sensor circuit.
22 Coolant temperature sensor circuit.
24 Throttle position sensor.
25 IAC motor driven circuit.
27 Fault in injector driver interface circuit.
31 Purge solenoid circuit.
32 Fault in EGR diagnostics.
34 Speed control solenoid circuits.
33 A/C cutout relay circuit.
35 Fan control relay circuit.
41 Charging system excess or no field current.
42 ASD relay circuit.
43 Fault in ignition coil control circuit.
44 Battery Temp Voltage.
46 Battery voltage too high.
47 Battery voltage too low.
51 Oxygen feedback system stuck at lean position.
52 Oxygen feedback system stuck at rich position.
53 Internal logic module problems.
54 Fault in the distributor high data rate pickup circuit.
55 Completion of fault code display.
62 Indicates unsuccessful attempt to update EMR mileage.
63 Unsuccessful attempt to write to an EEPROM location by the controller.
Possible causes:
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Jun 21, 2009 at 2:15 PM
