1993 Dodge Stealth 1993 dodge stealth won't start
JERRYCHAP
Electrical problem
1993 Dodge Stealth 6 cyl Front Wheel Drive Manual
It wouldn't start, technician could not get reading from computer. Replaced computer, now it still won't start. Spark plugs are firing, new fuel pump, new fuel pressure regulator. it tries to start but won't.
Jun 19, 2009 at 8:21 AM
MITSUMA06
  • 7 POSTS
from my experience it could be any one of a number of things... heres a few posibilities. any chance the timing belt may have skipped a tooth or two? that could cause it to not start. do a compression check and leak down test to make sure. also try using a noid light to check and make sure the injectors are getting a signal from the ecm and hook up a fuel pressure tester to make sure A) the fuel pump is turning on and B) the injectors arnt leaking at all. next you can test the maf sensor. ive see before where the maf dies and causes the car to not start but generates no codes. hope this helps.
Jun 21, 2009 at 2:12 PM
