1992 Dodge Stealth Radiator fans do not run
DAREN740
  • 1992 DODGE STEALTH
Engine Cooling problem
1992 Dodge Stealth Front Wheel Drive Manual 225000 miles
What is most common reason why both cooling fans will not run?
Monday, June 22nd, 2009 AT 7:41 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Will either run when you turn on the A/C high? If they do then most liklely problem is either engine coolant temp. Sensor or cooling fan relay. If they don't then wiring must be bad to them or somehow both motors failed at once. Highly unlikely though.
Monday, June 22nd, 2009 AT 7:48 PM
