1991 Dodge Stealth Won't Start
WR
I have a 1991 Dodge Stealth that wont start. I have changed the fuel pump and filter. I have sent the computer off to be repaired. I have changed the battery. I have checked the spark to the rotor, it seems to be good. I turn the key, the engine turns over, but will not start. If I push it to about 25 mph, I can pop start it. It is a sohc 5 speed. Any help would be appreciated.
Aug 20, 2007 at 9:43 AM
  • 75,988 POSTS
[quote:f0e91aa7ea="wr"]I have a 1991 Dodge Stealth that wont start. I have changed the fuel pump and filter. I have sent the computer off to be repaired. I have changed the battery. I have checked the spark to the rotor, it seems to be good. I turn the key, the engine turns over, but will not start. If I push it to about 25 mph, I can pop start it. It is a sohc 5 speed. Any help would be appreciated.[/quote:f0e91aa7ea]
Check your fuel pump relay and oil sending unit
Aug 20, 2007 at 2:32 PM
Suggested Repair
Check the fuel pump relay and the oil sending unit.
Conversation Summary
The owner of a 1991 Dodge Stealth SOHC five-speed says the engine cranks but will not start, although it can be push-started. The fuel pump, filter, battery, and computer have already been replaced or repaired, and spark at the rotor appears good. The expert advises checking the fuel pump relay and oil sending unit.
