will not up shift or down shift through the gears ?
1991 DODGE STEALTH
INTRUDER
I have a 1991 Dodge Stealth rt automatic trans with 86,000 miles that will not up shift or down shift through the gears manually or otherwise.The car seems to be in high gear only (very slow takeoff up till 45mph then picks up speed fine) car can be manually down shifted to 2nd or low gear at speed with no change (not dropping to lower gears) any suggestions on what to check? Thanks!
Mar 26, 2006 at 12:27 PM
DANNY L
  • CAR REPAIR CONTRIBUTOR
  • 5,648 POSTS
Hello, I'm Danny.
The first thing you should check is the transmission fluid level and condition. Make sure the fluid level is within the proper fill range and the fluid condition is not burnt or dark brown in color. Here are a few tutorials for automatic transmissions for service and repair:
Next let's run the codes to see if any are stored:
https://www.2carpros.com/articles/retrieve-trouble-codes-for-chrysler-dodge-plymouth-odb1-1995-and-earlier-car-mini-van-and-light-trucks
It sounds like the first gear shift solenoid is stuck and not working. Please go over these guides and get back to us.
Aug 22, 2021 at 4:03 AM
