1991 Dodge Spirit Door Latch Stuck
JACKIE0127
we have a 91 Dodge Spirit, 110000 miles (car doesn't run right now) that had the door lock assembly moved on two doors and the doors were 'closed' (although they didn't close) and now the lock assembly is stuck and I can't close the doors[img:6945c6ca06]http://www.2carpros.com/forum/automotive_pictures/100709_Christis_Folder_010_1.jpg[/img:6945c6ca06]
Sep 17, 2007 at 1:16 PM
BMRFIXIT
  • 19,053 POSTS
hi there after seeing the pic i noticed ths latch is closed hold the door handle open and try to open the latch you can use a screw driver
https://images.2carpros.com/forum/automotive_pictures/99387_100709_Christis_Folder_010_1_2.jpg
Sep 17, 2007 at 2:47 PM
Suggested Repair
The latch is closed. Hold the door handle open and use a screwdriver to open the latch so the door can close.
Conversation Summary
On a 1991 Dodge Spirit, the door lock assemblies on two doors were moved and the doors were pushed closed without fully latching, leaving the latches stuck so the doors will not close. The expert noted the latch is closed and advised holding the door handle open while using a screwdriver to release the latch.
