HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Spirit
Engine
Symptoms
Not Running
SPONSORED LINKS
1993 Dodge Spirit
PMHICKS
MEMBER
1993 DODGE SPIRIT
1993 Dodge Spirit 4 cyl Front Wheel Drive Automatic
car turns overs but wont start acts like its out of gas but has a full tank in it
Saturday, November 1st, 2008 AT 9:39 AM
BLACKOP555
MECHANIC
You check for fuel pressure?
Also check for spark with a spark tester at all cylinders.
SPONSORED LINKS
Saturday, November 1st, 2008 AT 10:35 AM
BLACKOP555
MECHANIC
Spray some starting fluid down the throttle body and attempt to start it, does it run then? Run and stay on? Run and die out?
Saturday, November 1st, 2008 AT 10:40 AM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
Won't Start - Before That, Hesitation While Driving
Engine Cranks Strongly But Won't Start (doesn't Partially "catch" At All). Leading Up To This, There Was Intermittent Very Brief Engine...
Asked by
Arctican
1 ANSWER
1993
DODGE SPIRIT
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1993 Spirit Turns Over But Doesn't Start!!!!
1. Make And Model Of Your Car 1993 Dodge Spirit 2.5l 4 Cyl. 2. Include The Mileage 126,000 3. Automatic Transmission 4. 2 Wheel...
Asked by
plouton
1 ANSWER
1993
DODGE SPIRIT
1993 Dodge Spirit
Engine Mechanical Problem 1993 Dodge Spirit 4 Cyl Front Wheel Drive Automatic Started Stalling When Coming To A Stop, It Would Do This...
Asked by
Charles O
1 ANSWER
1993
DODGE SPIRIT
1990 Dodge Spirit Intermittently Car Will Not Start
1990 Dodge Spirit, 2.5l 4 Cyl. Automatic. 50k Original Miles. Had Steering Column Replaced By Previous Owner Due To Theft Attempt. I Have...
Asked by
webco317
1990
DODGE SPIRIT
Car Will Not Start Intermittingly
Changed Starter, A Few Days Latter It Would Not Start Again. Removed Starter To Have It Checked And It Was Fine, Put Starter Back On And...
Asked by
tapp1958
1 IMAGE
1994
DODGE SPIRIT
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Symptoms
Crankshaft Sensor Replacement
Online car repair manuals
