1991 Dodge Spirit Head gasket sealant
GMARSCHKE
Engine Cooling problem
1991 Dodge Spirit 4 cyl Two Wheel Drive Automatic
Had steam and slight condensation coming from the exhaust - wouldn't pass Oregon DEQ because of the "smoke". Bought some K&W Nanotech sealant and followed the instructions diligently. Not only is the steam continuing but now the condensation has gotten worse - constant water drips from the exhuast pipe. Could the sealant have made the issue worse or does it take time for it to work?
Aug 29, 2009 at 3:42 AM
  • 110,245 POSTS
Where are you getting condensation (what part of the exhaust)? Is it coolant?
Oct 16, 2009 at 4:56 PM
GMARSCHKE
The smoke is coming from the tail pipe - along with drop of water - an almost constant flow of both smoke & water vapor - no anti freeze.
Used nano-tech sealant as directed - no help - in fact seemed to make it worse.
Oct 17, 2009 at 9:37 AM
  • 110,245 POSTS
IS the smoke white?
Oct 17, 2009 at 5:13 PM
GMARSCHKE
Nope - pretty clear - it looks, feels (hot), and smells like steam. Car remains off-line.
Nov 7, 2009 at 5:46 AM
  • 110,245 POSTS
The only thing, other than condensation, that is a liquid is coolant. Have you noticed that the coolant level is dropping? The only thing I can think of is a head gasket. You may want to check engine compression.
Nov 7, 2009 at 2:28 PM
