1994 Dodge Spirit how to check computer
1994 DODGE SPIRIT
PINYSTAB
Computer problem
1994 Dodge Spirit 4 cyl Front Wheel Drive Automatic
car just turns over will not start up sparks plugs are firing,does this car have crankshaft and camshaft sensor,how to check them
May 8, 2010 at 8:01 AM
Hi pinystab, Welcome to 2carpros and TY for the donation.
You're getting spark nothing is wrong with the CMH and CPS -check the fuel pressure you might not be getting fuel due to a defective fuel pump or there's no injection pulses.
May 8, 2010 at 12:23 PM
PINYSTAB
can not hear fuel pump come on,how to test electric plug for power and pressure
May 9, 2010 at 12:48 AM
Disconnect fuel pump connector and check for power on the dark green and black wire-if none do below
Check and test fusible link white at rear of battery, fuel pump relay at left fender shield
May 9, 2010 at 9:07 AM
