1991 Dodge Spirit car wont start
DUSTER19721974
  • 1991 DODGE SPIRIT
Engine Mechanical problem
1991 Dodge Spirit 6 cyl Front Wheel Drive Automatic
Car ran about an hour ago but now it will just turn over but not fire.
Friday, January 16th, 2009 AT 9:04 PM
ISLAND_PRIDE71
  • 62 POSTS
Have you checked for spark? If you haven't, disconnect a sparkplug wire and ground it to the engine and get a helper to crank the engine over. Are you getting a blue spark? If you are, then you need to check the fuel pressure if it's within specifications to verify that the fuel pump is working and producing the correct fuel pressure. And also, check if the injectors are pulsing. No blue spark check for power to the coil/s, test the distributor pick-up coil, ignition control module, if it has a camshaft and crankshaft sensors test that too.
Friday, January 16th, 2009 AT 10:52 PM
