1993 Dodge Shadow Stalls, No Fuel
JBLIMLINE
I was wondering if anyone knows if there is a safty switch for the fuel system on the 1993 dodge shadow 4 clinder... I was driving down the road and came to a stop at a stop sign. When i went to accelerate the car stalled... any help would be good.. there is spard but no gas getting to carb. thank you
Dec 9, 2006 at 10:09 AM
BACKYARDMECHANIC
  • 337 POSTS
I know Fords have a saftey switch but not sure about Dodge. Check the owns manual. If there is a switch the manual will show you where it is and how to reset it. If there is no reset switch then you have a problem with the fuel system. Check the fuel pump fuse and relay and make sure they are good.
Hope this helps Backyardmechanic
Dec 10, 2006 at 2:58 AM
Suggested Repair
Check the owner's manual for a fuel safety switch and reset procedure. If none is listed, inspect the fuel pump fuse and relay, since spark is present but fuel is not reaching the carburetor.
Conversation Summary
The owner of a 1993 Dodge Shadow said the engine stalled when accelerating from a stop, with spark present but no fuel reaching the carburetor, and asked about a fuel-system safety switch. The expert noted that Fords have such a switch but was unsure about Dodge, and recommended checking the owner's manual for a reset. If there is no switch, the expert advised checking the fuel pump fuse and relay.
