1988 Dodge Shadow Rotor Not Turning
TRAVLER02
[b:168414a48c]I have a 1988 dodge shadow. While driving it just quit. I had no spark so I check the distributor, the rotor will not spin when cranking. I check gear on end of distributor its ok, what could be wrong?[/b:168414a48c]
Dec 19, 2006 at 8:56 AM
BACKYARDMECHANIC
  • 337 POSTS
Does you car have a timing belt or chain . Motors that have belts use the belt to drive the distributor,along with the water pump,and cam shaft, causing it to turn. I suspected the timing belt (if equipped with one) has broken and this is the reason way the rotor does not spin. Good luck Backyardmechanic :(
Dec 19, 2006 at 9:11 AM
Suggested Repair
If the engine uses a timing belt to drive the camshaft, water pump, and distributor, inspect the belt. A broken timing belt would stop the distributor rotor from turning and cause a no-spark condition.
Conversation Summary
The owner of a 1988 Dodge Shadow said the engine quit while driving and had no spark. The distributor rotor would not turn while cranking, although the gear on the end of the distributor appeared fine. The expert explained that a timing-belt engine uses the belt to turn the distributor along with the water pump and camshaft, and suspected a broken timing belt.
