1992 Dodge Shadow Blinkers Not Working
SHADOW92
ok, I have a Dodge Shadow 92, problem is my blinkers wont work, i changed my flashers... and i messed around with it for 2 weeks now...i cant find the fuse box or any wires...i also checked my hazard lights to see if they worked, and the didnt...any ideas? im open to any thing :!:
Jul 15, 2006 at 9:12 AM
MIKEYBDMAN
  • 623 POSTS
[quote:3407c56838="shadow92"]ok, I have a Dodge Shadow 92, problem is my blinkers wont work, i changed my flashers... and i messed around with it for 2 weeks now...i cant find the fuse box or any wires...i also checked my hazard lights to see if they worked, and the didnt...any ideas? im open to any thing :!:[/quote:3407c56838]
Looks like the turn signal flasher is on the drivers side in the center of the A/C duct. Located on the left instrument panel support. If this is one you have changed, then never mind. There is a fuse, listed as fuse #15 10amp. It may also go thur the Hazard Warning Flasher which is a round flasher locared on the relay module.
Jul 15, 2006 at 11:32 AM
TTBUG
[quote:c66a0d429f="Mikeybdman"][quote:c66a0d429f="shadow92"]ok, I have a Dodge Shadow 92, problem is my blinkers wont work, i changed my flashers... and i messed around with it for 2 weeks now...i cant find the fuse box or any wires...i also checked my hazard lights to see if they worked, and the didnt...any ideas? im open to any thing :!:[/quote:c66a0d429f]
Looks like the turn signal flasher is on the drivers side in the center of the A/C duct. Located on the left instrument panel support. If this is one you have changed, then never mind. There is a fuse, listed as fuse #15 10amp. It may also go thur the Hazard Warning Flasher which is a round flasher locared on the relay module.[/quote:c66a0d429f]
I have a 93 Convertible. Is the location the same as the 92 mentioned above? My 15 yr son just bought this car and I have to figure out how to make the blinkers work, as well as the brake lights. Any info would be appreciated. :)
Aug 31, 2007 at 11:41 PM
Suggested Repair
Check fuse #15 (10 amp). The turn-signal flasher is on the driver's side, in the center of the A/C duct on the left instrument panel support. Because the hazards also fail, check the round hazard warning flasher on the relay module.
Conversation Summary
The owner of a 1992 Dodge Shadow reported that the turn signals and hazard lights do not work after replacing the flashers, and could not locate the fuse box or related wiring. An expert identified fuse #15 (10 amp), the turn-signal flasher on the left instrument panel support at the A/C duct, and the round hazard flasher on the relay module. A later question about a 1993 convertible was not answered.
