93 dodge shadow
1993 DODGE SHADOW
GRANDPAMIKE43
i have a 93 dodge shadow with a 2.5 seems like its not getting enough gas it bogs out when you push the peddle i have chaged the fuel pump the fuel filter map sensor timings right relays are working fuses are good and replaced thottlebody any ideas
Oct 7, 2007 at 9:06 PM
GRANDPAMIKE43
i just replaced the motor it did the same thing with the othere motor
Oct 8, 2007 at 8:19 AM
GRANDPAMIKE43
[quote:6116c58fb4="Rodimus-Prime"]still doesnt answer my question of when bog accurs[/quote:6116c58fb4] weather the engine is cold or hot it bogs out i jujust undid the exust and its not pluged to if that helps
Oct 8, 2007 at 2:27 PM
GRANDPAMIKE43
[quote:ff82602abd="Rodimus-Prime"]wasnt gonna suggest the exhaust for this one. im just trying to figure out if its a tranny not shifting right or a bad distributor pickup.
i pressume of course you done the key on and off 3 times left on on 3rd and read the blinking engine light codes of course
the possibliltys are faulty map sensor, wrong ecu, etc its one of those if i could just drive the car i would have a good idea cases.[/quote:ff82602abd] hey i changed map sensor you cant drive the car it will die evan in park and you try to rev it up it bogs i checked codes ok 12 opens codes then i got 13.14,31,the 55 closed it i have all the books that tell me what the codes are so if you dont tell me and i will type them out hey if you have msn mine is grandpamike44@hotmail.com
Oct 8, 2007 at 10:43 PM
