1994 Dodge Shadow fuel pump
BRAT39BREN
  • 1994 DODGE SHADOW
Electrical problem
1994 Dodge Shadow 4 cyl Two Wheel Drive Automatic
where fuel pump fuses located
Friday, September 18th, 2009 AT 6:59 PM
It doesn't have a fuse of its own-it gets its power from the ASD realy thru the fuel pump relay and then to fuel pump
Try directing power from the battery positve to the dark green and white wire at the f/pump connector this should power it up-if not the pump is defective
Friday, September 18th, 2009 AT 7:11 PM
