1988 Dodge Ramcharger
BRITTNEYLESHAE87
  • 1988 DODGE RAMCHARGER
My truck is full of gas, but died on the way to work this morning as if it ran out and now it won't start back up. I just filled it up yesterday. What could be the problem? It tries to start but won't
Wednesday, October 14th, 2009 AT 6:34 AM
It tries to start but won't. Do below to determine if its a fuel or spark related problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Wednesday, October 14th, 2009 AT 6:40 AM
