1985 Dodge Ramcharger starting
QALIRON
  • 1985 DODGE RAMCHARGER
  • V8
  • 4WD
  • 215,000 MILES
Hello, I am having trouble starting my 85 dodge ramcharger. It has a 318 motor. I can turn it but it wont fire up. I checked the main wire to the distributor cap and there is spark. I can smell fuel when I try to start it so Im thinking it may not be a fuel issue, Is there any other problem I could check in to? I am not a mechanic but I am not afraid to try, thanks
Monday, November 9th, 2009 AT 8:08 AM
You got spark-Now check the fuel pressure if its within specs and check for injection pulses.
Monday, November 9th, 2009 AT 9:57 AM
BRANDON SIMON
  • 49 POSTS
Check fuel pressure, check distributor for spark to plugs, and check plugs. Also, check to see if distributor cap is damaged, as that can cause similar issues. What is the condition of the battery? If it is an older battery, it may not have the power to properly start the vehicle. There are alot of things that can cause this issue, but we have to narrow things down to be able to pinpoint the problem.
Monday, December 24th, 2018 AT 10:35 AM
