1994 Dodge Ram Stalls Off Throttle
KEPPENF
I just bought a 1994 dodge ram 1500 4x4 w 171,000miles. My intentions are simple, fix it up right. Although When I accelerate and then let off the gas, the RPMs drop so low that it dies. Then it takes a moment to start it back up. Is this a electrical/wiring problem or should i be looking at the fuel filter/pump. I'm stumped. Any ideas?
Mar 20, 2007 at 4:00 PM
TYLER_25
I'm having the same problem, When you find out can you please tell me what to do? My truck is a 1988 Dodge Ram 150 Series 318 V-6 PLease help me.
Sep 10, 2007 at 5:14 PM
  • 55,694 POSTS
I would service the throttle bore and IAC motor. here is a guide and I have left the location of the IAC motor in the diagrams below. Here is a guide that can help as well:
https://www.2carpros.com/articles/stall-at-idle
and
Jul 22, 2022 at 3:05 AM
Suggested Repair
Service and clean the throttle bore and the idle air control (IAC) motor, then recheck idle after letting off the throttle.
Conversation Summary
A 1994 Dodge Ram 1500 stalls when the driver accelerates and then lets off the gas, with RPMs dropping until the engine dies and a brief delay before restart. The owner asked whether to check wiring or the fuel filter and pump. Another owner reported a similar stall on a 1988 Dodge Ram. The expert recommended servicing the throttle bore and IAC motor and pointed to idle-stall and throttle-actuator guides plus IAC location diagrams.
