1996 Dodge Ram 1500 Gas in Oil
THALONER
i have a 1996 dodge ram 1500 with the 318 and 118764 miles on it. it has a small oil leak. i have always kept a close eye on it to make sure i don't go to low on oil. recently i've noticed that it has not been loosing any oil, but the oil is discolored and smells strongly of gas. im thinking that it is getting gas pumped int the crankcase. my question is, is that possible, and if so, what would cause it?
Feb 17, 2007 at 1:57 PM
SERVICE WRITER
  • 9,123 POSTS
It's definitley possible. If the cylinders are not buring the fuel effieciently that will happen. a misfire for example is the most typical. If not present, make sure the plugs, wires, cap and rotor are up to snuff.
Feb 17, 2007 at 2:21 PM
Suggested Repair
Check for a misfire and inefficient combustion. Inspect and service the spark plugs, plug wires, distributor cap, and rotor if they are worn or not in good condition.
Conversation Summary
The owner of a 1996 Dodge Ram 1500 with a 318 engine reports a small oil leak, but the oil level is no longer dropping. The oil is discolored and smells strongly of gasoline, raising concern that fuel is entering the crankcase. The expert says this is possible when fuel is not burned efficiently, most typically from a misfire, and recommends checking the plugs, wires, cap, and rotor.
