1999 Dodge Ram Van Front Brake Pull
Suggested Repair
Diagnose the brake pull before replacing parts. Check caliper slide surfaces and how hard the piston is to press back, plus uneven or beveled pad wear. Also inspect brake hoses and suspension, and clean and adjust the rear brakes. If the front brakes are replaced, replace the rotors rather than turning them.
Conversation Summary
The owner of a 1999 Dodge Ram Van 1500 with ABS front disc brakes reported front brakes locking or pulling right under light pressure, sometimes smoothing out after light dragging. An inspection recommended turning rotors and replacing calipers, pads, and possibly bearings. The expert said a stiff caliper is possible and advised checking pad wear, slide surfaces, piston movement, hoses, suspension, and rear brakes. Rear brakes should be cleaned and adjusted, and rotors replaced rather than turned if front brakes are renewed.
