1995 Dodge Ram Cherry Red Converter
XBLADE77
I have a 1995 Dodge Ram 1500 conversion van 140000 miles. We have been noticing lately that once we get down to 3/4 of a tank of gas that it acts like it is empty, it hiccups and chugs and finally dies. Well, last night at the car wash it died mid wash. When we tried to start it back up again all it did was turn the starter but it wouldn't catch. We noticed that we had exast coming out when we tried to start it that smell like sulfur. When we finally got a push out of the car wash we looked underneath and saw that the catalytic converter was cherry red. We know the fuel pump is going out, but would that cause sudden problems with the exaust?
Mar 4, 2007 at 12:18 PM
  • 75,988 POSTS
[quote:47c74f1ee0="xblade77"]I have a 1995 Dodge Ram 1500 conversion van 140000 miles. We have been noticing lately that once we get down to 3/4 of a tank of gas that it acts like it is empty, it hiccups and chugs and finally dies. Well, last night at the car wash it died mid wash. When we tried to start it back up again all it did was turn the starter but it wouldn't catch. We noticed that we had exast coming out when we tried to start it that smell like sulfur. When we finally got a push out of the car wash we looked underneath and saw that the catalytic converter was cherry red. We know the fuel pump is going out, but would that cause sudden problems with the exaust?[/quote:47c74f1ee0]
You're dumping fuel big time-check the pressure regulator/injectors for stuck open and could be a weak ignition. Also do a back pressure test on the exhaust system.
Mar 4, 2007 at 1:04 PM
Suggested Repair
Check the fuel pressure regulator and injectors for sticking open, since excess fuel is likely being dumped. Also check for weak ignition and perform an exhaust backpressure test.
Conversation Summary
A 1995 Dodge Ram 1500 conversion van with 140,000 miles stumbles and dies as the fuel level drops, then failed to restart after dying at a car wash. Exhaust smelled of sulfur and the catalytic converter was cherry red. The owner suspects a failing fuel pump. The expert said the engine is dumping fuel and advised checking the pressure regulator and injectors for sticking open, checking for weak ignition, and doing an exhaust backpressure test.
