I have a 1999 Dodge Ram 2500 cargo van. 5.2L V8, Auto trans, A/C, 52000 miles. It has a radio but no other electric conveniences. A few weeks ago the engine quit on me. It started right up again. The next time it would only crank but not start. All gages were at zero and a message "no buS" were in the odometer window. I did not get a trouble code in tha code reader. Sometimes it runs and sometimes it does not. I will continue to trace this intermittent problem but would appreciate any sugestions as to the cause.
Update: I have traced the problem, I think, to the driver side (there are three) 32 pin connector to the computer, located in the heat above the engine. Wiggling indevidual wires does not seem to make any difference. If I push hard on the connector I can get the engine to work again. Could a curcuit board in the computer have a crack in it? It seems to solid a moumting for that to happen.
Jul 25, 2007 at 11:45 AM
