2005 Dodge Ram Rattling Noise
2005 DODGE RAM
65,600 MILES • 6 CYL • 4WD • AUTOMATIC
VVETTER
When drive vehicle and take foot off accelerator a loud rattling noise comes from right front wheel. We have replaced hub but has not changed noise. Do we need to replace drive line or what is next step?
Thanks.
Jun 22, 2009 at 7:50 AM
RACEFAN966
  • 5,029 POSTS
Have you checked the front axle for play and did you check the front driveline ujoints for play? If not do that first and then we will go from there.
Jun 23, 2009 at 2:17 AM
VVETTER
The front right drive axle felt good and tight when we put it back in.. The cv joints felt ok... We think it might be a differential bearing on the IFS front differential.... The noise dont just happen when you are rolling without throttle. it seems to be always there... You can hear it better when you take your foot off the throttle.. It's didn't seem to be a rattle but more of a bearing noise
Jun 24, 2009 at 12:49 AM
RACEFAN966
  • 5,029 POSTS
Have you check the front hub assembly? If not then I would, use a longer screwdriver or an automotive stethiscope and lift the front wheel and spin it listening to the bearing and see if you hear any noise coming from it. Here is a pic of the assembly.
https://images.2carpros.com/forum/automotive_pictures/249564_89464_1.jpg
Jun 24, 2009 at 2:27 AM
VVETTER
We just replaced the front hub assembly.
Jun 24, 2009 at 5:41 AM
RACEFAN966
  • 5,029 POSTS
Ok did it fix it?
Jun 25, 2009 at 1:48 AM
VVETTER
No...this was stated in my first posting.
Jun 25, 2009 at 4:52 AM
RACEFAN966
  • 5,029 POSTS
Ok so when you turn corners tight corners do you hear any clicking noises? Have you checked the caliper to see if it loose or if the brake pads are loose. One or the other could be and causing this noise too. Let me know what find.
Jun 26, 2009 at 2:53 AM
