2005 Dodge Ram
PINETOP1520
  • 2005 DODGE RAM
2005 Dodge Ram 6 cyl Four Wheel Drive
I am trying to remove a hub/bearing assembly. It is seized in their big time. Any advice or tricks?
Tuesday, April 14th, 2009 AT 11:42 AM
CUSTOMCURVES
If you are trying to remove the front wheel bearing hub, then what you have to do is make a spacer about 1inch in dia. And long enough to go between the inside axle housing and the axle u/j, then you turn the steering wheel so it pushes against the spacer and the housing, you do this on the front and back of the housing you will be pushing the axle and wheel bearing hub out together, some times you have to start the engine to use the power steering
Tuesday, April 14th, 2009 AT 3:08 PM
