2002 Dodge Ram hub assembly replacement
2002 DODGE RAM
HAWKSNEST
Drive Train Axles Bearings problem
2002 Dodge Ram V8 Two Wheel Drive Automatic
how does the bearing hub assembly come apart ?i have removed the clalipars &braket,and the three bolt in the rear side that holds the bearing assembly.
thank you for vyour time mike hawkins
Dec 21, 2009 at 8:19 AM
BLUELIGHTNIN6
  • 16,542 POSTS
to remove the hub/bearing assembly do the following..
remove brake caliper and rotor, remove ABS speed sensor (if equipped), remove the 3 mounting bolts from the steering knuckle, slide the hub/ bearing out of the steering knuckle, remove brake dust shield.
if bearing or hub is bad then you must replace the entire assembly. bearing is sealed for life and not servicable separately.
Dec 21, 2009 at 5:00 PM
