2004 Dodge Ram Rear Differential Leaking From Driveshaft In
31,500 MILES • V8 • 4WD • AUTOMATIC
DANGTP
I have a 2004 Dodge Ram 1500 with 31,500 miles and a 5.7 HEMI. Recently I have noticed that my rear differential is leaking fluid from the driveshaft input. Is this a bad seal or is this a sign of the rear end leading to failure? I have checked the fuild level and it is still in the normal range.
Sep 5, 2008 at 4:16 PM
BMRFIXIT
  • 19,053 POSTS
Its a seal issue
as long as u keep the fluid up to level u should be fine
have the seal replace when u can
Sep 5, 2008 at 10:17 PM
DANGTP
Thanks for the input. I will get it replaced A.S.A.P. It should be covered under the 7 year/70k mile powertrain warranty.
Sep 6, 2008 at 10:28 AM
BMRFIXIT
  • 19,053 POSTS
YES IT SHOULD BE COVERED
GOOD LUCK
THANK YOU
Sep 6, 2008 at 12:19 PM
