Ignition Coil?
TJNH
  • 1995 DODGE RAM
  • V8
  • 177,500 MILES
1995 DODGE RAM 1500, 5.2 L VIN :Y I have no power to the ignition coil
Wednesday, July 8th, 2020 AT 10:47 AM (Merged)
LEGITIMATE007
  • 5,121 POSTS
Check crank position sensor/hall effect switch.
CARADIODOC
  • 33,916 POSTS
There will only be voltage to the coil, injectors, alternator field, O2 sensor heaters, and fuel pump or pump relay when the engine is rotating, (cranking or running), not just with the ignition switch turned on.
Caradiodoc
