2003 Dodge Ram Won't start...again.
118,000 MILES • V8 • FWD • AUTOMATIC
KIMMES30
Ram overheated and needed the radiator replaced after noting a hole in it. Replaced radiator and hose. Next day wouldn't start. Next they replaced the distributor cap and replaced the water pump. Next day, it overheated. They said the radiator hose was lose and they replaced a spark plug saying it wasn't firing. Within 2 days, truck wouldn't start again. It turns over but will not crank. They are saying it's getting plenty of fuel, plenty of spark and that it may now be a blown head gasket? If the radiator cap is removed after trying to crank it will bubble over when the cap is removed...but once it stops bubbling the truck will crank. Any suggestions, or is it most likely the head gasket?
Nov 20, 2009 at 9:31 AM
PHIL95RAM
  • 7 POSTS
Pull the oil dip stick or drain the oil pan. If the oil looks milky, it's a head gasket.
Nov 25, 2009 at 2:39 PM
PHIL95RAM
  • 7 POSTS
Pressure test the radiator. By doing this it will make leaks in other places show their selves by putting the radiator under pressure at a cool temp. Be sure not to over pressurize usually 15lbs. is all,and make sure to use the proper personal protective equiptment.
Nov 25, 2009 at 2:43 PM
