Ok
I went home and tried to start truck, it turnd over many times but woldnt fireso batery and starter good
then I hooked up fuel pressure gage to fuel rail
turned key- pressure was 45psi
tried to start----engine turned over but didnt fire
ok must be spark issue
looked in chiltons manual (just purshased) under diagosis, engine turn over no start
it said check battery, which I know is good
then said nutral saftey switch
so I got back in truck put foot on brake
shifted trans from part to 1st then back to park
turned key and truck started
so I am happy it was that simple
but on older cars that I had if nutral saftey switch
was bad the engine wont turn over
so did I really find the problem?
Wednesday, February 11th, 2009 AT 6:32 AM
