2003 Dodge Ram 1500 Stalls and Hesitates
WINFORDDJ
Alright I have a problem with my 2003 Dodge Ram 1500 4.7 v8 automatic trans. 2wd. with 78750 miles.
Recently the CEL came on while I was on a roadtrip. I noticed that when trying to accelerate in high gear, it struggles greatly when it reaches 3500 rpm, almost like it doesnt know what its supposed to do. My first thought was transmission because I thought it was failing to shift. However, I drove it and stopped at the store before work, and when i came out of the store (maybe 2 minutes) it would not start. So I walked to work, and was at work for roughly 9 hours. I walked back to my truck and it cranked right up. stopped at the store again (tempting fate yes I know) but it started right up AGAIN. However on the 25 mile drive home, it stalled out. I pulled over and shut off the ignition, it started right back up and I got on home just fine. So given the not starting after a short rest, the trouble accelerating suddenly I am thinking its the fuel pump. Do I need to replace the fuel pump, or do I need to go get drug tested?
Aug 10, 2007 at 8:15 PM
2CARPRO JACK
  • 11,533 POSTS
Hold off on the drug test...for now LOL .Have it scanned for the code/codes, that will give us a good place to start.When it stalls...does it just sign off or does it feel like it is running out of fuel?
Aug 12, 2007 at 1:47 AM
WINFORDDJ
[quote:9684df3895="2CarPro Jack"]Hold off on the drug test...for now LOL .Have it scanned for the code/codes, that will give us a good place to start.When it stalls...does it just sign off or does it feel like it is running out of fuel?[/quote:9684df3895]
It is a rough struggle, like its choking... you know, like the Astros in the playoffs.
Aug 12, 2007 at 4:59 AM
2CARPRO JACK
  • 11,533 POSTS
Autozone will scan it for free, have that done first, does sound like a low fuel pressure condition.
Aug 13, 2007 at 1:10 AM
Suggested Repair
Have the check-engine codes scanned first, then check for low fuel pressure before replacing the fuel pump.
Conversation Summary
The owner of a 2003 Dodge Ram 1500 4.7 reported a check-engine light, hesitation around 3500 rpm, a no-start after a short stop, and a stall that restarted immediately. The expert advised scanning for codes first and said the symptoms sound like a low fuel-pressure condition.
