1999 Dodge Ram won't start
BLEONARD
  • 1999 DODGE RAM
  • V8
  • MANUAL
  • 125,000 MILES
My dodge ram 1500 will not start. Even with starter fluid. No codes replaced electronic coil, replaced ecm. There were no codes before or after ecm replaced. Fuses were okay. Really stumped. Sure would love to figure this truck out. Thanks
Sunday, March 21st, 2010 AT 6:30 PM
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Sunday, March 21st, 2010 AT 6:36 PM
