1999 Dodge Ram non-functioning turn signal
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
GREGORYP
My turn signals are working occasionally. Both the left and right will work for the first “blink” or two then just stop. They will also work ok for a while then just stop working. I tried the hazard lights and they work fine. What do you think the problem is? How much do you think the repair will cost me?
Look forward to your suggestions.
Sep 5, 2009 at 12:31 AM
JDL
  • 16,098 POSTS
Welcome to the site. When the turn lites act-up, don't recycle the key or anything, if the vehicle is running, leave it running. Check fuse 10--10amp in fuse box, use testlite, that fuse circuit should be hot, key on. If it isn't hot, you need to backtrack circuit to ignition switch. If it is hot, there are several possibilities, combination flasher--turn switch--wiring circuits, I routinely check bulbs and sockets.
Sep 5, 2009 at 2:13 AM
