can you comunicate with the PCM ?
Connect jumper wire between ground and DLC connector terminal No. 11 (White/Black wire). Turn ignition off. Remove instrument cluster. Using external ohmmeter, measure resistance between ground and instrument cluster connector C1 terminal No. 9 (White/Black wire). If resistance is less than 5 ohms, go to next step. If resistance is 5 ohms or more, repair open White/Black wire.
Disconnect jumper wire. Connect jumper wire between ground and DLC connector terminal No. 3 (White/Black wire). Measure resistance between ground and instrument cluster connector C1 terminal No. 10 (Violet/Brown wire). If resistance is less than 5 ohms, replace instrument cluster. If resistance is 5 ohms or more, repair open Violet/Brown wire.
Apr 25, 2009 at 5:16 PM
