1997 Dodge Ram torque converter code P0740
DOCFIXIT
  • 18,828 POSTS
GREAT NEWS glad to hear
Yes ABS set when revung wheel off ground. Either pull ECM/PCM fuse or diconnect BATT should clear
Monday, November 8th, 2010 AT 11:12 AM
J.STIEG
  • 352 POSTS
I disconnected the battery and the lights went out, thanks. I am having another problem with the cruise control, and shifting is erratic. I got a output shaft sensor code. Can I do a circuit check or should I replace the sensor?
Sunday, November 21st, 2010 AT 4:08 AM
DOCFIXIT
  • 18,828 POSTS
What was code? 0720? Speedo accurate?
Monday, November 22nd, 2010 AT 2:11 PM
J.STIEG
  • 352 POSTS
I had a spring backwards on a lever on the transmission that might have been causing problems with the output speed sensor. The check engine light has not come on for a while, but there is still a problem. Its hard to tell if its the transmission or engine performance. I have recently had plugs, plug wires, cap and rotor replaced. It feels like there is binding and releasing, There is a little bit of poping noise on acceleration, but motor is fine reving up in park. I had the transmission out a two weeks ago. What should I try next?
Monday, November 22nd, 2010 AT 6:05 PM
