AC drain tube air conditioner was leaking into the truck
1997 DODGE RAM
TONIMARIE
My sister had my truck an i am in the process in shipping it here to alaska, well, my question is she told my mother that the air conditioner was leaking into the truck is this possible? or could it be my heater coil?
Aug 26, 2010 at 6:50 PM
WRENCHTECH
  • 20,761 POSTS
Either one of those things is possible. If the condensation drain is plugged up, it will leak condensation inside the car. It can usually be easily cleaned out.
Apr 23, 2021 at 11:54 AM
TONIMARIE
if it was the heater coil would it have a smell? an you mention the plug im not to sure where that is at would you happen to know an thank you so much for getting back to me so fast Toni
WRENCHTECH
  • 20,761 POSTS
You may be able to detect a sweet smell to coolant but not necessarily.
The A/C evaporator drains through the firewall on the passenger side into the engine compartment, down low. You will have to search for the drain and stick a coat hanger or something in there to clear the clog.
