2003 Dodge Ram AC not blowing cold
2003 DODGE RAM
INABOBINA
Air Conditioning problem
2003 Dodge Ram V8 Two Wheel Drive Automatic
i have a 2003 dodge ram 1500 i put gauges on it reading at 45 i've put a new line on thats has the ofice tube bulit into it at idle its hot when u drive it its fell like it is low on feron i've pull vacaum on the high side and lowside
Aug 6, 2009 at 8:35 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Did you replace drier during line replacement? What are low and high side readings? How much freon was put in ?
Let me know
Thanks for donate
Aug 6, 2009 at 8:53 AM
INABOBINA
the driyer was not replace the the highside lines are very hot and the lowside there is no condensation its fells very warm and i would say problem about 2-3 lbs
Aug 6, 2009 at 9:07 AM
DOCFIXIT
  • 18,828 POSTS
There is moisture in system Really need gagues hooked up . Assume you only have the little line and gague from auto parts store. low needs to be 35 at 85-90 deg ambient air temp.
Aug 6, 2009 at 9:25 AM
INABOBINA
no sir i have the real gauges high and low side so on the gauges what should it be reading at usally itreads at 45 how do i get the moisture out do i vacham it on how long and do i do the high side to
Aug 6, 2009 at 9:30 AM
INABOBINA
problem fixed
Aug 6, 2009 at 2:59 PM
