1996 Dodge Ram No Crank
RWGDKG
my 1996 dodge ram v-8 4by4 wont make a sound we have put new starter new battery in it its getting fire but wont start not even click please help what els could it be
Mar 16, 2007 at 8:28 AM
  • 75,988 POSTS
[quote:953403270e="rwgdkg"]my 1996 dodge ram v-8 4by4 wont make a sound we have put new starter new battery in it its getting fire but wont start not even click please help what els could it be[/quote:953403270e]
Try the anti theft device if it has one. Some ATD system kills the starter circuit when activated.
Oct 4, 2018 at 3:33 AM
STINGRAY-02
  • 13 POSTS
just posted a question you might would like the answer too also. I have the same problem but when key is turned on everything else working i can even hear the fuel pump prime the system. Now what I have figured out is that in the fuse block under the hood is a relay for the starter. Now I probably mmessed something up but i used a jumper on pin slot #30 and outside #87. It engaged my starter so i am leaning to bad relay will let you know how that turns out. Also remember when you pull out relay and look at bottom to see pin numbers that it is reversed from the slots you pulled it out of.
STINGRAY-02
  • 13 POSTS
Somebody told me it could also be the nutral start / back up light switch.
STINGRAY-02
  • 13 POSTS
Asked on December 11, 2010
1996 Dodge Ram with 0 miles
v8 318 = 5.2Liters Automatic 2 Wheel Drive
1996 Dodge Ram Relay check
starter not working. replaced starter worked for a few minutes . not working. pulled relay inserted jumper wire into where prong # 30 and #87 outer go starter engaged. could relay be bad how to check relay
Asked by Stingray-02
Replies
Replied on December 11, 2010
Have you checked for continunity?
Answered by Jacobandnickolas (expert)
31,021 answers provided
Swap it with a different one. Failure is very rare. Based on your tests and observations, I'd suspect the neutral safety switch.
When you can catch it not cranking, grab a test light, ground it to the engine or battery negative, then test the four terminals in the starter relay socket. (Middle terminal is not used). One will have battery voltage all the time. One will have 12 volts when you turn the ignition switch to "crank".
Next, clip the test light lead to the battery positive post and probe the two remaining terminals in the socket. The test light will light up all the time in one of them because it is finding low resistance to ground through the starter solenoid coils. The other one will read to ground through the neutral safety switch when the transmission is in park or neutral. If you find ground in only one terminal, suspect the neutral safety switch. The starter solenoid windings hardly ever go open circuit and you already found it working when you jumped the relay terminals.
caradiodoc
Answered by caradiodoc (expert)
STINGRAY-02
  • 13 POSTS
Worked for me I changed out my neutral start safety switch. It is located on the transmission just above the pan. On the drivers side. It is a 3 pin terminal.
Suggested Repair
Check the anti-theft system if equipped, since it can disable the starter circuit. Also test the under-hood starter relay and the neutral safety/backup light switch. On a similar 1996 Ram, jumping relay terminals 30 and 87 engaged the starter, and replacing the three-pin neutral start switch on the driver's side of the transmission fixed the no-crank condition.
Conversation Summary
The owner of a 1996 Dodge Ram V8 4x4 said it would not crank or click after a new starter and battery were installed, although it had power. An expert suggested checking the anti-theft system because it can interrupt the starter circuit. Another owner with the same symptom reported that the fuel pump primed and that jumping starter-relay terminals 30 and 87 engaged the starter. Experts advised checking relay continuity, swapping the relay, and testing the neutral safety switch. That owner later reported that replacing the three-pin neutral start safety switch on the driver's side of the transmission, just above the pan, solved the problem.
