1988 Dodge Ram 50 Won't Start
WILSON5R
  • 8 POSTS
i have a 1988 dodge ram 50 with the 2.6L, at, weber 2bbl. the truck wont start. when i pump the gas it kicks a few times but just wont start. the truck started/ran/drove fine the day before
Mar 3, 2007 at 4:56 AM
BUBBA_KOSKI
  • 129 POSTS
could be a couple things, but lets play this one at a time, check your air fuel mixture, on the carb, make sure it pulling in fuel, check spark, then compression.
Mar 3, 2007 at 5:40 AM
Suggested Repair
Check the carburetor air-fuel mixture and confirm it is pulling fuel, then check spark and compression.
Conversation Summary
The owner of a 1988 Dodge Ram 50 with a 2.6L engine and Weber two-barrel carburetor says it will not start after running fine the day before; pumping the gas makes it kick a few times. The expert recommends checking the carburetor mixture and fuel intake, then spark and compression.
