1987 dodge mini ram cargo van-v6
SMARTSAMMY
vandals pried-loose the driver's side door latch,key still works and the rod which pulls the lock open can be operated by hand,however i would like to re-install the now-loose door handle,or better yet,make it tight to the door as original.(manual window not power).
thanx.
Aug 8, 2007 at 5:42 AM
DPWD23
  • 136 POSTS
You will likely find all the parts you need at a junk yard. Take pictures of how yours is arrainged before taking them apart, and put in the ones from the junk yard door.
Some junk yards may make you buythe whole door, if so find one with broken glass so it's cheaper... you after all, only need the door handle parts.
Aug 10, 2007 at 11:08 AM
