If you aren't getting spark, or it's very weak, check my post out and see if it helps...
https://www.2carpros.com/forum/here-vp369725.html#369725
Yours sounds like carb or fuel pressure problems though.
I'm not ruling out timing, I have a D50 that had some parts come lose in the timing chain housing and they got caught in the chain/gear and popped a hole about the size of a silver dollar in the valve cover. If that happens, you just as well rebuild the whole thing if it uses oil or burns it, because the head is most likely going to need rebuilt.
Wednesday, October 15th, 2008 AT 8:34 PM
