1987 Dodge Raider
1987 DODGE RAIDER
180,384 MILES • 6 CYL • 4WD • AUTOMATIC
REPOMAUN07
i have a 87 dodge raider.the oil is not clear but a medium light color.i put water in radiator and tried to turn over and the water was coming out around the exhaust.is that a blown head casket or a blown motor.it was overheated once.can you help.
Dec 28, 2008 at 8:38 AM
  • 110,241 POSTS
Hi:
It sounds like a head gasket. Remove the head, check for evidence that the gasket was leaking. Also, check the head for cracks or warping.
Let me know what you find.
Mar 12, 2009 at 9:41 AM
FASTLAYNE
I would take a look to see if your head is warped, those aluminum heads arent very friendly with heat so you more than likely warped it
Jun 10, 2009 at 9:07 AM
