is Valvoline MaxLife ATF and acceptable replacement for ATF+4 fluid specified for Dodge vehicles?
May 23, 2006 at 1:49 AM
Use the correct ATF+4 fluid from a Dodge dealership rather than an unverified substitute. Keep proof of the fluid purchase in case it helps with later repair coverage.
The owner asked whether Valvoline MaxLife ATF is an acceptable replacement for the ATF+4 specified for Dodge vehicles. The expert recommended always getting the correct fluid from the dealership and keeping proof, noting that documented use of the proper fluid may sometimes help with repair coverage even after the warranty ends.
