1999 Dodge Intrepid ATF Cooler Leak
BLSTROUD
i have a '99 Dodge Intrepid with 130k miles, 3.2L engine. there is a small hole in the automatic transmission fluid cooler (that runs in front of the radiator). Parts houses sell a 'generic' type cooler for $30 - - $80. the Dodge part is $192. 1) Is there any issue with using the generic replacement on this?
2) to decide which generic part to use, the parts system asks "with super cool" or "without super cool". What does that mean? It also gives a choice of heavy duty, medium duty, and light duty - which would i want for this car?
May 21, 2007 at 3:22 AM
2CARPRO JACK
  • 11,533 POSTS
I would think the difference will be the way the fluid is pushed through the cooler. One will have just a tube that runs back and forth, the other is probably more like a radiator in that it pushes the fluid through small passages causing it to be cooled better.I would go with as close to the stock one size wise but the best cooling ability
May 21, 2007 at 4:12 AM
Suggested Repair
Replace the leaking transmission cooler with a unit close to the stock size that provides the best cooling, preferably a multi-passage radiator-style cooler rather than a simple tube.
Conversation Summary
The owner of a 1999 Dodge Intrepid with a 3.2L engine has a small hole in the automatic transmission fluid cooler and asks whether a generic cooler is acceptable, what "super cool" means, and which duty rating to choose. The expert explains that cooler designs differ in how fluid flows through them and recommends a unit close to stock size with the best cooling ability.
