1996 Dodge Caravan Expansion Valve Removal Fix
1996 DODGE
HELMERS99
On the air conditioniong system how do i remove the expansion valve that is on the firewall? i removed the nut that holds the ac hoses but what holds it to the ac evaporator?
Apr 16, 2006 at 2:10 AM
LOSONE
  • 1,616 POSTS
The valve should pop right off but the base is part of evaporator. It is probably stuck and corroded as often happens. Work it very carefully or you will snap the evaporator housing.
Apr 16, 2006 at 3:07 AM
HELMERS99
so there is no nut on the back side of the expansion valve?
Apr 16, 2006 at 3:09 AM
LOSONE
  • 1,616 POSTS
no nut just a flat fit with a metal washer which is probably corroded. Go to the Zone and get some rust inhibitor in a spary can. Put it on and let it sit for a couple of hours. Good luck
Apr 16, 2006 at 3:16 AM
Suggested Repair
The expansion valve has no rear nut; it is a flat fit with a metal washer and the base is part of the evaporator. Spray a rust inhibitor on the corroded joint, let it sit a couple of hours, then carefully work the valve free so the evaporator housing does not snap.
Conversation Summary
The owner of a 1996 Dodge Caravan had removed the nut holding the A/C hoses and asked what still held the firewall expansion valve to the evaporator. The expert said there is no rear nut, only a flat fit with a metal washer that is often stuck and corroded, and that the valve base is part of the evaporator. They advised spraying rust inhibitor, waiting a couple of hours, and working the valve off carefully to avoid breaking the evaporator housing.
