1999 Dodge 1500 Cracked Block
Usually if the block cracks, it is due to the coolant freezing. You have freeze plugs that can protect it, but they dont always work. If you have ever let the coolant get weak, it may have froozen and you not know it.
As for the $6k for a rebuild. Geeze! I know the dealership wants like $2500 for the block, but I am sure you can find one a lot cheaper.
Suggested Repair
Confirm exactly where the 5.2 block is cracked and whether coolant is entering the oil. An external crack may still be repairable, while a crack in the cylinder deck or lifter valley usually means the block is unusable. Weak coolant that froze is a common cause even without a known overheat. Compare a used or remanufactured block or long block with the dealer’s roughly $6,000 rebuild quote.
Conversation Summary
The owner of a garaged 1999 Dodge 1500 with a 5.2 V8 and 65,000 miles was told the block is cracked despite no known overheating, and the dealer quoted about $6,000 for a long-block rebuild without identifying the crack location. Replies say freezing from weak coolant is the usual cause because freeze plugs do not always protect the block. They also say an external crack without coolant in the oil may be repairable, while a deck or lifter-valley crack generally ruins the block, and a replacement block should cost less than the dealer rebuild.
