1993 Toyota Celica Cracked Air Hose
MMARK
93 celica ,120,000 mi, air hose to filter cracked. been sucking unfiltered air for who knows how long . am i looking for serious damage? such as?
Oct 4, 2007 at 8:04 AM
  • 31,937 POSTS
Hi there,
A fair proportion of the air entering the engine will be through the filter, if the are hose is only cracked it should not be a huge problem, needless to say that any unfiltered air is undesirable but these things do happen. Depending on where you live and the road conditions that you drive on will be a factor. Dusty outback roads will cause more problems than city driving. The problems will be long term, the grill entering the engine will be abrasive on rings and cyl walls, but i feel that you will have no worries and that the small amount of grill will not be a big problem. for any fault so show up in the short term you would be needing to toss in hand fulls to do serious short term damage.
Mark (mhpautos)
Oct 4, 2007 at 12:10 PM
Suggested Repair
Replace the cracked air intake hose so all intake air passes through the filter. A crack alone is unlikely to cause serious short-term engine damage, though dusty driving can increase long-term abrasive wear on the rings and cylinder walls.
Conversation Summary
The owner of a 1993 Toyota Celica with 120,000 miles reported a cracked hose to the air filter and asked whether prolonged unfiltered air could cause serious engine damage. The expert said most air would still pass through the filter if the hose was only cracked, so short-term damage was unlikely unless a large amount of grit entered. Dusty roads increase the risk more than city driving, and any grit could cause gradual long-term wear on the piston rings and cylinder walls.
